Patton Gateway Network problems
Discussion in '3CX Phone System - General' started by Jaco, Sep 18, 2008.
  1. Jaco
    Nov 6, 2006
    9
    I am implementing 3CX for a client using ISDN BRI lines with a Patton Smartnode gateway.
    I have found that if these gateways are connected to the network, but not powered, they seem to be generating a large amount of noise on the network. So much so, that it results in an average 50% dropped packet rate.
    I was curious to know if anyone else has been experiencing similar problems?
