Patton ISDN Progress Tone
Discussion in '3CX Phone System - General' started by max1, Mar 27, 2017.
  1. max1
    May 16, 2014
    21
    I have just installed a Patton Smartnode SN4120 with 2 x ISDN2e BRI's. Everything is working okay but have a minor issue when calling out. After dialling the number the progress tone is heard as though the callee's phone is ringing. Then a couple of seconds later another progress tone is heard. The second tone is when the SN4120 actually starts the call and the callee's phone rings, the first tone is 3CX calling the SN4120.
    Is there any way to ensure only one tone is heard?!
    Max
    10,741
    281
    3CX is most likely playing the ringback tone because of a progress message sent by the gateway. Perhaps there is an option, in the gateway, to suppress this message. The drawback might be, a long(ish) period of silence, before the actual audio ringback is received, which may cause the caller to believe that the call did not go through, and to hang up.
    Are you running the latest (supported) firmware?
  3. max1
    May 16, 2014
    21
    Hi Leejor,
    Yes the device is on the latest supported firmware. I will investigate the ringback (remove) option.
