Patton Manually Configuration
stash
Anyone tried to manually configure patton and made it work? I'm currently experimenting on something and the only way to achieve it i think is to manually configure patton gateway.
Thanks,
STASH
It isn't rocket science to manually configure any of the Smartnodes but even in custom setups we start with the 3CX config file and then manually tweak and change.
Hi Sigma,
You mean you upload first the config file on patton from 3CX and then configure manually the patton gateway?
Thanks,
STASH
Well, I don't understand your question. Obviously you can manually configure any of the Patton Gateways and make them work. If you are asking about manually doing anything I must assume that you are looking for something special (i.e. not included in the 3CX template). I would start anyway with a 3CX template config and then manually tweak whatever I wanted to make different. We often do that to add a default gateway for example... but much more as needed
Hi Sigma,
This will refer to my post on Multi Tenant. I want to use only one patton for 10 system. I was thinking to manually configure patton to create DID per system which on the post you mentioned i need a Class 4 Switch to achieve the setup i want to build.
Thanks,
STASH
Then PLEASE do not START 2 incomplete threads. If you plan on using an FXO gateway on the Patton, you can have an individual account for each FXO port that you can register to a specific 3CX PBX (but I find this moronic). If you think that you will share a gateway among several PBXs as a bank than the ONLY way to do it is to use a proper SBC/SBG or Class 4 switch or a spare 3CX PBX merely acting as a switch. Overall I find this a bad idea as I subscribe to the KISS philosophy.
Getting Started - Admin
Hammad.k
Get 3CX - Absolutely Free!
3CX
