Patton Outgoing Audio Problem
Discussion in '3CX Phone System - General' started by purpleone, Mar 22, 2010.
  1. purpleone
    Mar 18, 2009
    18
    I have a 3CX setup to a Patton 4114 FXO device. The system was configure by simply running the wizard to configure the patton device. Everything was running fine then all of a sudden, we have no outgoing audio on incoming calls only. Outgoing calls and internal calls are fine. When the call comes in, the user answers and cannot hear the caller, but the caller can hear the user. There have been no configuration changes. We have power cycled both devices, but no good still.
    Any one have any ideas???
    Thanks.
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Have you elimnated the phone to ensure that it is working? I would probably start by try to run a wireshark capture to see if audio is reaching the device first. Basically process of elimination.
    Also I would recommend you factory reset the device and reconfigure it from scratch.
