Patton PRI Gateway
Discussion in '3CX Phone System - General' started by pitrickzul, Mar 27, 2018.
  1. pitrickzul
    Mar 13, 2018
    58
    Have a question regarding the support for Patton PRI gateways. The new models only come on Trinity software and on the supported gateway page, it specifies that the trinity software is not supported. Any one using these gateway without issues? What are the other alternative?
  2. tratz
    tratz New Member
    Oct 21, 2015
    111
    16
  3. eddv123
    eddv123 Well-Known Member
    Aug 15, 2017
    1,577
    209
    Hi Pitrickzul,
    Alternately I do have Patton written templates for 3CX for the Trinity devices. Where they are not currently officially supported by 3CX they do work without issue and should be hopefully included in the foreseeable future.
    If you want them drop me a PM and I will send through.
  4. eddv123
    Aug 15, 2017
    1,577
    209
    Also just as a note on the Patton downgrade manual above. This applies only to models that support SmartWare in the first place. New models are Trinity only.
