Patton Reconfiguration
Discussion in '3CX Phone System - General' started by dcoxjr, Sep 25, 2012.
  1. dcoxjr
    Apr 24, 2012
    20
    When is it necessary to reupload a configuration file to a Patton PSTN device? If I make changes in 3CX under PSTN devices, do I need to reconfigure the PSTN device?
  2. mixig
    mixig Active Member
    Dec 13, 2011
    519
    11
    what changes have you done?
  3. netswork
    netswork Active Member
    Mar 11, 2011
    577
    If its a PRI the only time you would need to regenerate the config is if you changed the number of channels. But I have also found the 3cx generated configuration always configures it for 23 channels regardless of how many I set in 3cx. So I always manually modify that. Once I have uploaded the config and changed the channels I never have to touch the patton again. You can add and modify DID's and caller ID and what not without having to upload to the patton. If this is an analog gateway and you added or removed lines is the only time I would think you need to upload a new configuration.
