Patton Smart Node 4114 Slow Dialing Outbound
Discussion in '3CX Phone System - General' started by Aaron Cannata, Jun 12, 2017.
  1. Aaron Cannata
    Jun 7, 2017
    I have a Patton SN4114 VOIP Gateway that is on the latest firmware. We are using 3CX Version 15.5. I am consistently getting 7 sec delay from the time a call is sent to the time it rings. Is there a way to shorten that? I have the trunk set to "Wait for Dial Tone" with the same result. Changing it to 1 or 2 seconds does not change anything.
    #1 Aaron Cannata, Jun 12, 2017
  2. CentrexJ
    CentrexJ Member
    May 5, 2009
    458
    75
    Put in a ticket with Patton their tech support can help with that. They have free lifetime tech support don't be shy using it.
