Patton Smart Node - How to use all 5 ports
Discussion in '3CX Phone System - General' started by ziptalk, Aug 9, 2009.
  1. ziptalk
    ziptalk New Member
    Nov 16, 2008
    180
    All,
    I have setup a Patton SmartNode 4638 BRI 5-ports to connect to 4 x ISDN 2e boxes, and they work fine.
    I would like however, to use the 5th available port, and as it happens I have a spare ISDN 2e box with a 10 range DDI associated to it.
    However, following the setup guide by 3CX http://www.3cx.com/voip-gateways/smartnode-isdn.html It explicitly states:
    I have logged into the Patton device and can see that this port is disabled.
    Is there any reason why I can't use this ? I am going to enable it, but thought I'd ask in case there are things I need to be aware off!
    Thanks,
    Lewis
  2. tpinnovations
    tpinnovations Member
    Jul 30, 2009
    296
    I have only used the PRI devices from the IAD, But I would like to think the setup is similar just with different interfaces.
    3CX Allows you to create a config file that can be uploaded to the device, The config file that is created is specifically for use with 3CX. It will switch the INT_0 / INT_1 as the primary interface, and configure the voice settings, but other then that it seems to work like a charm. I would see no problem in using the 5th port to add a bridge to another Patton device or set it up as another Gateway. I'm just not sure how you would configure that particular device to do that.
