Patton Smartnode 4114 Error
Discussion in '3CX Phone System - General' started by brentrichburg, Apr 26, 2011.
  1. brentrichburg
    Nov 16, 2010
    30
    I get the following email error on an outbound call.
    _______________________________
    (0) TC-3CX 4/25/2011 7:06:46 PM
    Call to 97740146@(Ln.10000@Patton 1) has failed. [ V4 10.9.27.251:5060 UDP target domain=unspecified mFlowKey=820 ] replied: 502 Bad Gateway; from IP:10.9.27.251:5060
    _____________________________________
    Here is the corresponding log entry
    _______________________________________________
    19:06:50.004 [CM505002]: Gateway:[Patton 1] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Patton SN4114 JO EUI 00A0BA0605A5 R5.3 2009-01-15 H323 SIP FXS FXO M5T SIP Stack/4.0.28.28] PBX contact: [sip:10001@10.9.25.82:5060]
    The call does connect correctly on the port that it says has failed, however I get an error email every single time that route is used. Inbound calls generate no errors.
    Any suggestions?
  2. Josh Gurkin
    Aug 15, 2012
    Bump. I have just begun to experience this same error.
  3. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,088
    65
    Come now, the same? The first post is over a year old and while you may have the same symptom, it may not be caused by the same underlying issues.
    Need more detail about setup.
    How many ports are in use, are all available for outbound? Were any other calls in progress at the same time (either in or out). What version 3CX and how many sim calls supported? What rules are in place? Is this is a new install, or is it one that has been around for awhile and this just started. Do all the ports show as registered? How about some logs showing what 3CX thinks and preferably more that one line like the first poster showed?
  4. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    Contact Patton support it looks to be a gateway problem, as the log says bad gateway.
  5. Josh Gurkin
    Aug 15, 2012
    The problem is identical. This system has been running for about 8 months. The system has 32 sim calls. All ports were available. This gateway has 4 lines all connected. The only rule affecting this call is to use the Patton.
    Email
    Call to XXXXXXXXXX@(Ln.10003@Patton-1) has failed. [ V4 192.168.2.12:5060 UDP target domain=unspecified mFlowKey=820 ] replied: 502 Bad Gateway; from IP:192.168.2.12:5060
    Log
    08:37:40.897 [CM505002]: Gateway:[Patton-1] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Patton SN4114 JO EUI 00A0BA06FB94 R6.1 2012-05-09 H323 SIP FXS FXO M5T SIP Stack/4.0.30.30] PBX contact: [sip:10000@192.168.2.11:5060]
    I told you it was the same error. I had already checked the logs. The only difference is the Serial Number/MAC of the Device and firmware versions.
  6. lneblett
    Sep 7, 2010
    2,088
    65
    OK, got it and my apologies. I try and answer many questions on the forum and the number of folks who say "I have exactly the same problem" where it may be the same problem, but not the same cause/effect or set-up is quite frequent. I can only ask for more detail in the hopes that I might be able to spot something that could be the root cause.
    In your case, I don't see any such indication. I can only offer that a reboot of the appliance might bring it back, but failing that it looks like a call to Patton is in order.
  7. jpillow
    Jun 20, 2011
    1,342
    Have you checked to see if the firmware on the gateway is the most recent release?
