- Joined
- Nov 5, 2012
- Messages
- 84
- Reaction score
- 11
I installed 3 Patton Sn4114 4 fxo ports for analog trunks.
i upgraded them to the latest firmware and applied the config file generated by the 3CX system.
i am able to call out and receive call correctly.
I have an issue while talking to an external party and both users talk at the same time the audio of the other end will cut off for a second.
If i make a little sound, the audio will cut off and comes back after a seconds. I know this isnt normal with the 3CX itself because if i call the voicemail i can talk and the audio will not be affected. I also connected a sip trunk on that system and did the same test without the issue happening.
anyone have seen this?>
I am now sure the issue if with the Patton.
i am using yealink T46G and T48G with latest firmware supported by 3CX.
