Patton SmartNode 4634: errors with generated config
Discussion in '3CX Phone System - General' started by wohlert, Mar 25, 2008.
  1. wohlert
    Mar 24, 2008
    Hi everybody from 3CXsupport,
    I used the button "Generate config file" and imported the file in my Patton SmartNode 4634 (Patton Software Version : R4.2 2008-01-17 H323 SIP BRI).
    The following errors occures:
    1970-01-01T01:00:30 : LOGWARNING : Config: Line 95: SN4634/3BIS/UI(if-sip)[IF_SIP_0]#route default dest-interface IF_ISDN_0
    1970-01-01T01:00:30 : LOGWARNING : Config: % ^ Keyword mismatch
    1970-01-01T01:00:30 : LOGWARNING : Config: Line 103: SN4634/3BIS/UI(if-sip)[IF_SIP_1]#route default dest-interface IF_ISDN_1
    Then I changed the config to:
    route call dest-interface IF_ISDN_0
    route call dest-interface IF_ISDN_1
    and it works.
    Additionaly I added the following lines for callback with my VoIP-Phone:
    context cs switch
    national-prefix 00
    international-prefix 000
    I was positive surprised from the function to generate this config only with a mouseclick, so I think it would be perfect to correct this...
    Regards
