Patton SmartNode 4960
Discussion in '3CX Phone System - General' started by blackwing, Mar 9, 2012.
  1. blackwing
    Mar 9, 2012
    Just curious if there someone here knows how to set-up patton smartnode 4960? Just a basic LAN setup and sharing of internet connection to the network(direct leased line connection)
  2. Ian Joyce
    Oct 9, 2009
    51
    Here you go:
    http://www.888voip.com/configuring-a-patton-4960-pri-gateway-with-3cx/
  3. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    There are step by step instructions on 3cx's blog page.
