Patton Smartnode Help
Discussion in '3CX Phone System - General' started by shanus6, May 21, 2015.
  1. shanus6
    Apr 16, 2015
    17
    Hey Guys,
    Wondering if anyone can help me out.
    Purchased a Patton SN4112 FXS unit.
    It has 2 FXS ports and 1 Eth Port.
    First thing i did was connect the unit to my LAN, located it via the Dsicovery Tool downloaded and applied the latest firmware..That went perfect.
    Next i logged into the 3CX Console, went to VOIP/PTSN Gateways,
    Selected Add Gateway, SN4112 FXS etc etc
    I set the Host/Gateway IP to 192.168.0.93 as this is the IP address i would like the Gateway to use. Selected the 2 extensionsi would like the unit to control and downloaded the config file.
    Logged back into the SmartNode, imported the config file, Reloaded. The unit received the new IP of 192.168.0.93 and thats where it goes downhill. The VOIP Link light on the front flashes and the unit never registers in either the "Phones" Tab or the Gateway tab. The 2 extensions are also Unregsitered.
    Below is the config file, can anyone see any problems? Cheers for any help
    (Note the IP of my 3CX System is 192.168.0.37)
    Provider: IF_SIP_3CX
    Local: 192.168.0.37
    Remote: 192.168.0.37:5060
    Max Endpoints: 32
    Early Proceeding: yes
    Hold Method: zero-ip
    Early Connect: no
    Early Disconnect: no
    Call-Transfer: accept & emit ; expires: 60
    Call-Reroute: disabled
    AOC Format: asn1
    AOC-S Information: disabled
    AOC-D Information: disabled
    AOC-E Information: disabled
    Overlap dialing: disabled
    PRACK: Accept: disabled, Emit: disabled
    Pull-In Externally Looped Calls: yes
    Address-Complete Indication: Accept: clear
    Use Privacy: no
    Outgoing Call Parameter Source
    From Header
    User: from call URI or E.164 ()
    Host-Port: from call URI or E.164 :)0)
    To Header
    Host-Port: from interface remote :)0)
    Request URI
    User: from To header ()
    Host-Port: from To header :)0)
    Target Parameter: none (Target: , Cause: )
    Identity Header
    Header User: from call URI or E.164 ()
    E.164 Emit Mode: from call URI or E.164 (single-primary)
    Header Host-Port: from call URI or E.164 :)0)
    Diversion Header
    Header Host-Port: none :)0)
    Incoming Call Parameter Source
    Calling Party
    E.164: from Identity header ()
    URI: from Identity header (sip:anonymous@example.com)
    Name: from Identity header ()
    Redirecting E.164: (invalid) (Target: , Cause: Unknown)
    Called Party
    E.164: from Request-URL ()
    URI: from Request-URL (sip:anonymous@example.com)
    Name: from To header ()
    Play Tones: yes
    VoIP Profile: default
    Used: by 2 module(s)
    Voice Codecs
    G.711 A-law: Rx=20ms Tx=20ms
    G.711 u-law: Rx=20ms Tx=20ms
    G.729A: Rx=20ms Tx=20ms
    Fax Codecs
    T.38 UDP: Rx=1ms Tx=1ms Relay
    Modem Codecs
    G.711 A-law: Rx=20ms Tx=20ms Disable-Echo-Canceller Voice-Band-Data
    Codec Negotiation: enabled
    Response Preferred Codec: (undefined)
    Dejitter
    Mode: Adaptive
    Max. Delay: 60ms
    Max. Packet Loss: 4/1000
    Shrink Speed: 1
    Grow Step: 1
    Grow Attenuation: 1
    High Pass Filter: enabled
    Post Filter: enabled
    CED Net Detection: disabled
    CED Net Observe Time: 3000ms
    CED Net Detect Time: 300ms
    Fax
    Detection: CED Tone
    T.38 High Speed Redundant Packets: 0
    T.38 Low Speed Redundant Packets: 0
    Max. Bit Rate: 14400bps
    Volume: -9.500dB
    Error Correction: enabled
    HDLC: enabled
    Dejitter Max Delay: 200ms
    Max Datagram Size: 244 Byte
    Fax and Modem Detection Timeout: 0
    Modem
    Volume: -9.500dB
    HDLC: enabled
    DTMF
    Relay: enabled
    Relay-method: Default
    Signaling-vendor: Default
    Mute Encoder: enabled
    FLASH-HOOK
    Relay-method: DTMF
    RTP
    Payload Type NTE: 101
    Payload Type NSE: 100
    Payload Type Transparent: 91
    Payload Type Transparent-cisco: 116
    Payload Type Clearmode: 97
    Payload Type Redundancy: 255
    Payload Type G.726-32: 2
    Payload Type G.726-32-CISCO: 2
    Payload Type G.726-32-AAL2: 2
    BCD
    Activation: on-rx-activation
    Timeout: 1000
    Traffic Class: local-voice
    SDP
    Ptime Announcement: disabled
    SIP Profile: default
    Used: by 1 module(s)
    Autonomous Transitioning: disabled
    Tone-Set Profile: default
    Routing Destination: router (IF_SIP_3CX-precall-service)
    State: Up
    Allow New Calls: yes
    Allow Incoming Calls: yes
    Wait For Name: no
    Wait For Number: no
    Proceeding Timeout: 4000
    Early Alerting Timeout: 0
    Endpoints
    Endpoint: IF_SIP_3CX-012a32c8
    Local: 192.168.0.37
    Session-Timer Interval: 0s
    Early Connect: no
    AOC
    AOC-S
    AOC-D
    AOC-E
    X-Org-ConnID
    Play Tones: yes
    Call Routing Destination: router (IF_SIP_3CX-precall-service)
    Active State: Trying
    Passive State: Idle
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    Can you check under Settings / Security / IP Blacklist / that the gateway is not blocked ? If it is just remove it from the list and apply.
    Furthermore, ensure that you are running latest Smartware firmware available from Patton website for this model prior to configuring it.
  3. shanus6
    Apr 16, 2015
    17
    Thanks for your reply.
    I can confirm the Gateway IP is not blocked. I even have an ALLOW rule for all traffic from 191.168.0.1-192.168.0.99
    I did however check because I know Block Rules take priority over allow rules.
    I downloaded and applied the latest firmware from the Patton website before configuration, still no luck.
  4. shanus6
    Apr 16, 2015
    17
    As a further bit of information, if I lift the receiver on one of the two analogue handsets there is a dial tone but if I dial a number nothing happens. I'm guessing this must be the SmartNode providing a dial tone as opposed to the 3CX System.
  5. leejor
    11,277
    360
    You say that the device has two FXS ports, but no FXO ports? If it is just two FXS, then it is two extensions, and the config file you posted does not show any signs of extension numbers, or other specific settings that one would normally associate with an extension, just "general" configuration information.
    So..there is either more to the config file, or there is an additional file that contains this information.
    I assume that when checking the 3CX Server log, that there is no sign of a registration attempt.
  6. leejor
    11,277
    360
    Dialtone will always come from a VoIP phone, or ATA, not from the PBX itself.
    Did you follow this?
    http://www.3cx.com/voip-gateways/patton-smartnode-sn4112-fxs/
  7. shanus6
    Apr 16, 2015
    17
    Hi Leejor,
    Sorry I copied what I thought was the config file out of one of the screens on the SmartNode GUI,
    I completely overlooked that but I do know that when I was hunting around troubleshooting in the file that downloaded from my 3CX system the username and password etc were in there (I'm currently out of the office so I can't paste the file but I will do as soon as I get back)
    There are no registration attempts in the logs
    Yes, that is the exact guide I followed
  8. shanus6
    Apr 16, 2015
    17
    Ok here is the config file that 3CX Generates..
    # For SN-4112 2-port FXS
    # Supported firmware versions R6.x
    # Author: Kevin Attard Compagno
    # Contact: kevin@3cx.com
    timer CONFIG_UPDATE now + 2 minutes every 10 minutes "provisioning execute CONFIG"
    webserver port 80 language en
    sntp-client
    system
    ic voice 0
    low-bitrate-codec g729
    profile ppp default
    profile call-progress-tone defaultDialtone
    flush-play-list
    play 1 1000 425 -6 450 -6
    profile call-progress-tone defaultAlertingtone
    flush-play-list
    play 1 400 425 -13 450 -13
    pause 2 200
    pause 2 2000
    profile call-progress-tone defaultBusytone
    flush-play-list
    play 1 375 425 -7
    pause 2 375
    profile call-progress-tone defaultReleasetone
    flush-play-list
    play 1 375 425 -7
    pause 2 375
    profile call-progress-tone defaultCongestiontone
    flush-play-list
    play 1 375 425 -7
    pause 2 375
    profile tone-set default
    profile voip default
    codec 1 g711alaw64k rx-length 20 tx-length 20
    codec 2 g711ulaw64k rx-length 20 tx-length 20
    codec 3 g729 rx-length 20 tx-length 20
    fax transmission 1 relay t38-udp
    modem transmission 1 bypass g711alaw64k rx-length 20 tx-length 20
    profile pstn default
    profile sip default
    profile aaa default
    method 1 local
    method 2 none
    profile provisioning CONFIG
    destination configuration
    location 1 tftp://$(dhcp.66)/${system.mac}
    activation reload graceful
    context ip router
    interface IF_IP_LAN
    ipaddress 192.168.0.93 255.255.255.0
    tcp adjust-mss rx mtu
    tcp adjust-mss tx mtu
    context cs switch
    no digit-collection timeout
    routing-table called-e164 RT_DIGITCOLLECTION
    route .T dest-interface IF_SIP_3CX MT_EXT_TO_NAME
    routing-table called-e164 RT_TO_FXS
    route 126 dest-interface IF_FXS_00
    route 125 dest-interface IF_FXS_01
    mapping-table calling-e164 to calling-name MT_EXT_TO_NAME
    map 126 to "Boardroom"
    map 125 to "Jane"
    interface sip IF_SIP_3CX
    bind context sip-gateway GW_SIP_ALL_EXTENSIONS
    route call dest-table RT_TO_FXS
    remote 192.168.0.37 5060
    local 192.168.0.37 5060
    trust remote
    interface fxs IF_FXS_00
    route call dest-table RT_DIGITCOLLECTION
    subscriber-number 126
    interface fxs IF_FXS_01
    subscriber-number 125
    context cs switch
    no shutdown
    authentication-service AS_ALL_EXTENSIONS
    realm 1 3CXPhoneSystem
    username boardrm password *******
    username jane password *****
    location-service LS_ALL_LINES
    domain 1 192.168.0.37
    identity-group default
    authentication outbound
    authenticate 1 authentication-service AS_ALL_EXTENSIONS
    registration outbound
    registrar 192.168.0.37 5060
    lifetime 300
    register auto
    identity 126 inherits default
    identity 125 inherits default
    interface LAN
    bind interface IF_IP_LAN context router port 5060
    bind location-service LS_ALL_LINES
    no shutdown
    port ethernet 0 0
    medium auto
    encapsulation ip
    bind interface IF_IP_LAN router
    no shutdown
    port fxs 0 0
    use profile fxs au
    encapsulation cc-fxs
    bind interface IF_FXS_00 switch
    no shutdown
    port fxs 0 1
    use profile fxs au
    bind interface IF_FXS_01 switch
    no shutdown
  9. shanus6
    Apr 16, 2015
    17
    The device is running Firmware R6.7 2015-01-06 H323 SIP FXS
    Still trying to get it to work. Any ideas?
