- Joined
- Jun 24, 2015
- Messages
- 6
- Reaction score
- 0
Hi guys,
I switched to the PATTON SN4528 gateway, which has 4 FXO and 4 FXS.
(I don't use the FXS as for now)
I chose the SN4524 model (when I set it up in the 3cx), generated the file and uploaded it to the gateway.
3cx shows the line with green color (Trunk status), but I can't dial out, only receive calls.
Here is the log:
26-Jul-2015 17:05:55.483 [CM506001]: STUN request to resolve SIP external IPort mapping is sent to STUN server 198.50.247.220:3478 over Transport 10.0.0.11:5060
26-Jul-2015 17:01:43.200 [CM503008]: Call(C:13): Call is terminated
26-Jul-2015 17:01:43.199 Leg L:13.1[Extn] is terminated: Cause: CANCEL from 10.0.0.19:51931
26-Jul-2015 17:01:39.624 Leg L:13.2[Line:10001>>0547341122] is terminated: Cause: 504 Server Time-out/INVITE from 10.0.0.4:5060
26-Jul-2015 17:01:39.624 [CM503025]: Call(C:13): Calling T:Line:10001>>0547341122@[Dev:sip:[email protected]:5061,Dev:sip:[email protected]:5062,Dev:sip:[email protected]:5063] for L:13.1[Extn]
26-Jul-2015 17:01:39.621 Call to T:Line:10001>>0547341122@[Dev:sip:[email protected]:5060,Dev:sip:[email protected]:5061,Dev:sip:[email protected]:5062,Dev:sip:[email protected]:5063] from L:13.1[Extn] failed, cause: Cause: 504 Server Time-out/INVITE from 10.0.0.4:5060
26-Jul-2015 17:01:39.621 [CM503003]: Call(C:13): Call to <sip:[email protected]:5060> has failed; Cause: 504 Server Time-out/INVITE from 10.0.0.4:5060
26-Jul-2015 17:01:28.643 [CM503025]: Call(C:13): Calling T:Line:10001>>0547341122@[Dev:sip:[email protected]:5060,Dev:sip:[email protected]:5061,Dev:sip:[email protected]:5062,Dev:sip:[email protected]:5063] for L:13.1[Extn]
26-Jul-2015 17:01:28.595 [CM503027]: Call(C:13): From: Extn:10 ("Natanel " <sip:[email protected]:5060>) to T:Line:10001>>0547341122@[Dev:sip:[email protected]:5060,Dev:sip:[email protected]:5061,Dev:sip:[email protected]:5062,Dev:sip:[email protected]:5063]
26-Jul-2015 17:01:28.595 [CM503004]: Call(C:13): Route 1: from L:13.1[Extn] to T:Line:10001>>0547341122@[Dev:sip:[email protected]:5060,Dev:sip:[email protected]:5061,Dev:sip:[email protected]:5062,Dev:sip:[email protected]:5063]
26-Jul-2015 17:01:28.595 Line limit check: Current # of calls for line Lc:10004(@1[<sip:[email protected]:5063>]) is 0; limit is 1
26-Jul-2015 17:01:28.595 Line limit check: Current # of calls for line Lc:10003(@1[<sip:[email protected]:5062>]) is 0; limit is 1
26-Jul-2015 17:01:28.595 Line limit check: Current # of calls for line Lc:10002(@1[<sip:[email protected]:5061>]) is 0; limit is 1
26-Jul-2015 17:01:28.595 Line limit check: Current # of calls for line Lc:10001(@1[<sip:[email protected]:5060>]) is 0; limit is 1
26-Jul-2015 17:01:28.595 Call(C:13): Call from Extn:10 to 90547341122 matches outbound rule 'Rule for 1'
26-Jul-2015 17:01:28.594 [CM503001]: Call(C:13): Incoming call from Extn:10 to <sip:[email protected]:5060>
Don't know what to do... please advise.
Thanks!
Here is the log:
Thanks!
