Patton SN4634 - what soft version recommendation?
Discussion in '3CX Phone System - General' started by o.mascia, Feb 18, 2009.
  1. o.mascia
    Oct 6, 2008
    14
    I will soon upgrade two Patton SN4634. They're equipped with the default initial 4.2 release. I run 3CX version 7 (licensed). What would seem the best soft version to upgrade to? The latest 4.2 or 5.1 ? 5.2 ? What is the experience of those of you running that same product?
    Thanks !
  2. alexmallia
    alexmallia New Member
    3CX Support
    Aug 4, 2008
    130
    It is recommended to use the firmware R4.2 dated September 2008.
    regards
  3. o.mascia
    Oct 6, 2008
    14
    Thanks, that's done.
