Patton t1 gateway Configuration
Discussion in '3CX Phone System - General' started by gregja1310, May 1, 2017.
  1. gregja1310
    Apr 19, 2017
    7
    hi i have problem setting up my SN4970,
    i used the 3cx setup guild and the device registers with 3cx but fails to recive or make outgoing calls,
    Keep getting this error via 3cx:
    05/01/2017 3:20:23 PM - [CM503025]: Call(C:27511): Calling T:EndCall:EndCall@[Dev:sip:EndCall@127.0.0.1:5483;rinstance=1910dbb162c65e39] for L:27511.1[Extn:1009]
    05/01/2017 3:20:23 PM - [Flow] Call(C:27511): making call from L:27511.1[Extn:1009] to T:EndCall:EndCall@[Dev:sip:EndCall@127.0.0.1:5483;rinstance=1910dbb162c65e39]
    05/01/2017 3:20:23 PM - [CM503016]: Call(C:27511): Attempt to reach <sip:98551345@192.168.1.4:5060> from Extn:1009 has failed. Reason: Temporarily Unavailable
    05/01/2017 3:20:23 PM - L:27511.1[Extn:1009] failed to reach Out#:>>Rule{9400002}>>98551345, reason Temporarily Unavailable
    05/01/2017 3:20:23 PM - Call(C:27511): from L:27511.1[Extn:1009]: There are no available outbound lines on Trunk 'PSTNlinePatton ISDN T1' at this time. First line: 10008
    05/01/2017 3:20:23 PM - Call(C:27511): Call from Extn:1009 to 98551345 matches outbound rule '9400002'
    05/01/2017 3:20:23 PM - [Flow] Call(C:27511): has built target endpoint: Out#:>>Rule{9400002}>>98551345 for call from L:27511.1[Extn:1009]
    05/01/2017 3:20:23 PM - [CM503010]: Call(C:27511): Making route(s) from Extn:1009 to <sip:98551345@192.168.1.4:5060>
    05/01/2017 3:20:23 PM - Remote SDP is set for leg L:27511.1[Extn:1009]
    05/01/2017 3:20:23 PM - [CM505001]: Endpoint Extn:1009: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone for Windows 15.0.60903.0] PBX contact: [sip:1009@192.168.1.4:5060]
    05/01/2017 3:20:23 PM - [CM500002]: Call(C:27511): Info on incoming INVITE from Extn:1009: Invite-IN Recv Req INVITE from 192.168.16.110:59718 tid=Pj0e15aa44eed84f37bb2e5fc007ea7597 Call-ID=485f952a4e64451097a6a71b16317541: INVITE sip:98551345@192.168.1.4;tag3cx=240de40dc79c44a1853f5c0dbc9bedf3 SIP/2.0 Via: SIP/2.0/TCP 10.247.56.165:59718;rport=59718;branch=z9hG4bKPj0e15aa44eed84f37bb2e5fc007ea7597;received=192.168.16.110;alias Max-Forwards: 70 Contact: <sip:1009@192.168.16.110:58941;rinstance=0-0b10690234a24ac68ffb166493de609a;ob>
  2. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    I'm not sure that your Patton and 3cx are talking yet, based on the "There are no available outbound lines on Trunk 'PSTNlinePatton ISDN T1' at this time. First line: 10008" comment ...
    If you're currently available I could teamviewer in and troubleshoot it with you, shouldn't be too hard.
  3. gregja1310
    Apr 19, 2017
    7
    i saw that after and adjusted the outbound rule and now saw the traffic hitting the gateway:
    this is the 3cx error now:
    05/01/2017 5:50:58 PM - Call(C:29461), Extn:1009 on exit: DlgInfo(29461-1696/Early / I)
    05/01/2017 5:50:58 PM - Call(C:29461), Extn:1009 on entry: DlgInfo(29461-1696/Initial / I)
    05/01/2017 5:50:58 PM - Notify dialog-info: Extn:1009: sip:1009@192.168.16.110:60391;rinstance=0-675a6c2fded742d69ac0c05f1fc6ecd7;ob, Call(C:29461)
    05/01/2017 5:50:58 PM - [CM503025]: Call(C:29461): Calling T:EndCall:EndCall@[Dev:sip:EndCall@127.0.0.1:5483;rinstance=1910dbb162c65e39] for L:29461.1[Extn:1009]
    05/01/2017 5:50:58 PM - [Flow] Call(C:29461): making call from L:29461.1[Extn:1009] to T:EndCall:EndCall@[Dev:sip:EndCall@127.0.0.1:5483;rinstance=1910dbb162c65e39]
    05/01/2017 5:50:58 PM - [CM503016]: Call(C:29461): Attempt to reach <sip:98551345@192.168.1.4:5060> from Extn:1009 has failed. Reason: Server Failure
    05/01/2017 5:50:58 PM - L:29461.1[Extn:1009] failed to reach Line:10008>>8551345, reason Server Failure
    05/01/2017 5:50:58 PM - Call to T:Line:10008>>8551345@[Dev:sip:10008@192.168.1.19:5060] from L:29461.1[Extn:1009] failed, cause: Cause: 503 Service Unavailable/INVITE from 192.168.1.19:5060
    05/01/2017 5:50:54 PM - [CM503025]: Call(C:29461): Calling T:Line:10008>>8551345@[Dev:sip:10008@192.168.1.19:5060] for L:29461.1[Extn:1009]
    05/01/2017 5:50:54 PM - [Flow] Call(C:29461): making call from L:29461.1[Extn:1009] to T:Line:10008>>8551345@[Dev:sip:10008@192.168.1.19:5060]
    05/01/2017 5:50:54 PM - [CM503027]: Call(C:29461): From: Extn:1009 ("Derval Rose" <sip:1009@192.168.1.4:5060>) to T:Line:10008>>8551345@[Dev:sip:10008@192.168.1.19:5060]
    05/01/2017 5:50:54 PM - [CM503004]: Call(C:29461): Route 1: from L:29461.1[Extn:1009] to T:Line:10008>>8551345@[Dev:sip:10008@192.168.1.19:5060]
    05/01/2017 5:50:54 PM - Call(C:29461): Call from Extn:1009 to 98551345 matches outbound rule '9400002'
    05/01/2017 5:50:54 PM - [Flow] Call(C:29461): has built target endpoint: Out#:>>Rule{9400002}>>98551345 for call from L:29461.1[Extn:1009]
    05/01/2017 5:50:54 PM - [CM503010]: Call(C:29461): Making route(s) from Extn:1009 to <sip:98551345@192.168.1.4:5060>
    05/01/2017 5:50:54 PM - Remote SDP is set for leg L:29461.1[Extn:1009]
    05/01/2017 5:50:54 PM - [CM505001]: Endpoint Extn:1009: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone for Windows 15.0.60903.0] PBX contact: [sip:1009@192.168.1.4:5060]
    05/01/2017 5:50:54 PM - [CM500002]: Call(C:29461): Info on incoming INVITE from Extn:1009: Invite-IN Recv Req INVITE from 192.168.16.110:61335 tid=Pj15713bf48dd84db6a0a81095dbf960f0 Call-ID=e8a3a62e443044ae9f6bb32d0bfb1fb1: INVITE sip:98551345@192.168.1.4;tag3cx=0f104e9fefd146808452d6452124d63b SIP/2.0 Via: SIP/2.0/TCP 192.168.16.110:61335;rport=61335;branch=z9hG4bKPj15713bf48dd84db6a0a81095dbf960f0;alias Max-Forwards: 70 Contact: "Derval Rose" <sip:1009@192.168.16.110:60391;rinstance=0-675a6c2fded742d69ac0c05f1fc6ecd7;ob> To: <sip:98551345@192.168.1.4;tag3cx=0f104e9fefd146808452d6452124d63b> From: "Derval Rose"<sip:1009@192.168.1.4>;tag=69f0265b1b8f45cabd7a6aa1b16c98c9 Call-ID: e8a3a62e443044ae9f6bb32d0bfb1fb1 CSeq: 13032 INVITE Session-Expires: 1800 Min-SE: 90 Allow: PRACK, INVITE, ACK, BYE, CANCEL, UPDATE, INFO, SUBSCRIBE, NOTIFY, REFER, MESSAGE, OPTIONS Content-Type: application/sdp Proxy-Authorization: Digest username="1245",realm="3CXPhoneSystem",nonce="414d535c0f183ebd27:73f976566636a2f9021cee9c4f5aefeb",uri="sip:98551345@192.168.1.4;tag3cx=0f104e9fefd146808452d6452124d63b",response="fef829602d558e5be28cb2b708d265e4",algorithm=MD5 Supported: replaces, 100rel, timer, norefersub User-Agent: 3CXPhone for Windows 15.0.60903.0 Content-Length: 426 v=0 o=- 3702650443 3702650443 IN IP4 192.168.16.110 s=pjmedia b=AS:84 t=0 0 a=X-nat:0 m=audio 42008 RTP/AVP 3 18 0 8 9 96 c=IN IP4 192.168.16.110 b=TIAS:64000 b=AS:84 a=rtcp:42009 a=sendrecv a=rtpmap:3 GSM/8000 a=rtpmap:18 G729/8000 a=fmtp:18 annexb=no a=rtpmap:0 PCMU/8000 a=rtpmap:8 PCMA/8000 a=rtpmap:9 G722/8000 a=rtpmap:96 telephone-event/8000 a=fmtp:96 0-15 m=video 0 RTP/AVP 31 c=IN IP4 127.0.0.1
    05/01/2017 5:50:54 PM - [CM503001]: Call(C:29461): Incoming call from Extn:1009 to <sip:98551345@192.168.1.4:5060>
    05/01/2017 5:50:54 PM - Leg L:29461.1[Extn:1009] has external party ID {}
    05/01/2017 5:50:54 PM - NAT/ALG check:L:29461.1[Extn:1009] REQUEST 'INVITE' - some of SIP/SDP headers may contain inconsistent information or modified by intermediate hop SIP contact header is not equal to the SIP packet source(IP:port): Contact address:192.168.16.110:60391 Received from :192.168.16.110:61335
  4. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    Server Failure is really not a better error to have ;)
    Teamviewer ?? I'm bored for the next 30 minutes or so and we're both online. PM me !
  5. gregja1310
    Apr 19, 2017
    7
    if you still want to connect let me know
  6. gregja1310
    Apr 19, 2017
    7
    ID 541 400 480
  7. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    lol, in private ;)
