Patton Updates are available for V14 SP2
Discussion in '3CX Phone System - General' started by neville, Dec 8, 2015.
  1. neville
    neville New Member
    Apr 23, 2012
    202
    33
    V14 SP2 has Patton updates available. The old template was dialing 0/Operator whatever number you dialed. I reported it to support yesterday and they had updates available this morning. Big shout out to 3CX support for the quick fix.
  2. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    14
    Can you elaborate on the issue this fixed? I use Patton gateways, but I haven't run into any issues, but I'd like to be sure.
  3. neville
    neville New Member
    Apr 23, 2012
    202
    33
    Under SP2 and old templates, when you dial a number, the Patton would only send out a 0 and get to the LEC operator. All numbers went to the Patton though. Patton provided a quick fix and 3CX updated the templates.
  4. nb
    nb Support Team
    Jun 7, 2007
    2,097
    142
    this is sorted..
