Patton
Discussion in '3CX Phone System - General' started by maltese2000, Jun 10, 2016.
  1. maltese2000
    Apr 4, 2008
    Sto provando un 3cx con un patton 4112 2 FXO.
    Ho eseguito la procedura di configurazione, salvato il file e caricato sul Patton.
    non vedo pero' il patton stesso tra i gateway pstn.
    Qualche indicazione su cosa controllare ?
    3cx e' versione 12 update 6
    Grazie in anticipo
  2. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,283
    68
    When you used the Wizard to add the Gateway, are you sure you used the FXO option in the drop-down menu are did you choose the FXS option?
    When adding an FXS Gateway it does not show up in the PSTN Gateway list as it registers as extension(s).
  3. maddrm
    May 31, 2011
    6
    I am having a similar issue. I have a Patton 4114 and if you tell the wizard that there are 4 ports, it only creates the first port.
  4. NickD_3CX
    Jun 2, 2014
    1,283
    68
