Pause Call Recording
Discussion in 'Windows' started by GBC_James, Jul 11, 2017.
  1. GBC_James
    Feb 3, 2017
    61
    6
    I read that in the 15.5 update it will now be possible to pause the recording of a call.
    We tried it using the 15.5 windows client, but it doesn't work.
    we tried it using the new Browser based client, and it worked.
    So the pausing of recording seems to be there, but it just doesn't work in the Windows client.
    any idea if and when this will be resolved as it will be invaluable.
    thanks
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    420
    Hello @GBC_James
    Please note that this is a feature that only works with the Web client. If you would like to see this functionality added to the windows client you can request it by raising a feature request in the ideas section.
  3. GBC_James
    Feb 3, 2017
    61
    6
    Hi @YiannisH_3CX That explains it then :)
    I will request it in the ideas section
