Pause Recording
Discussion in '3CX Phone System - General' started by psykomotor, May 19, 2010.
  1. psykomotor
    Apr 24, 2008
    9
    Is it possible to pause/mute a recording in 3CX ? Preferably via an API.
    We've been been asked to quote on a PBX for a call centre which takes credit card details - and under the current PCI DSS rules the security codes cannot be stored.
    Note that the recording should not be split up if it is paused so it ends up as one file with a muted/skipped piece, but not two (or more if the agent moves back to the payment details screen). Although not preferred, It would be workable if there was some way to identify which files are part of the same call and in what sequence.
    Thanks in advance.
  2. Borsoock
    Borsoock New Member
    Apr 8, 2007
    149
    I'm affraid you will have to search for external reccording system, probably expensive one.
  3. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Please post this feature in the feature request section, it is monitored on a daily basis.
  4. psykomotor
    Apr 24, 2008
    9
    Should I repost or can a mod move the thread ?
    Thanks.
  5. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Repost it please :)
