Pause Recording
Discussion in '3CX Phone System - General' started by Schrodz, May 31, 2017.
  1. Schrodz
    Schrodz New Member
    Apr 21, 2017
    100
    14
    There was an old thread in 2015 regarding pausing the call recording but it is yet to be answered. We need this for PCI Competency instead of ordering a separate system. Do you know if this will be implemented soon?
    Or another way white noise can be injected into the recording
    Dan
  2. 3CXusername
    3CXusername New Member
    Jul 31, 2014
    183
    16
  3. Schrodz
    Schrodz New Member
    Apr 21, 2017
    100
    14
    Still no update :/
  4. 3CXusername
    Jul 31, 2014
    183
    16
    Judging by the two votes you probably aren't going to see much movement on this. At least Insperix solution (paid product) is an option...
  5. 3CXDude
    3CXDude New Member
    Oct 1, 2015
    110
    30
    There were a couple of threads on this topic and I'm pretty sure Nick confirmed it was on the roadmap (no time frame though)
    Search the ideas forum and you should find it.
