PBX Activity Monitor
Discussion in 'Ideas' started by DSXDATA, Aug 30, 2017.
PBX Activity Monitor 5 5 16votes
5/5, 16 votes
  1. DSXDATA
    DSXDATA New Member
    Oct 20, 2015
    185
    64
    Need a real-time monitor showing the activity of extensions, ring-groups, trunks.
  2. the60
    the60 New Member
    Oct 21, 2011
    117
    61
    queues...
    strint_echo and DSXDATA like this.
  3. DSXDATA
    DSXDATA New Member
    Oct 20, 2015
    185
    64
    Oh yes, and queues :rolleyes:
  4. vpage
    Mar 14, 2011
    7
    Yes! Need a monitor
  5. Carlos Teca
    Apr 3, 2017
    9
    Yes need a monitor is necessary because it's easy to detect any problem
  6. godsom
    Dec 7, 2017
    6
    Add real time monitor extension activity sort by extension groups for call out.
  7. strint_echo
    Oct 11, 2016
    What do you need that's not covered by /#/app/system_status/active_calls, /webclient/#/people, and /webclient/#/switchboard? I don't necessarily disagree, but I think you might need to be more specific.
    #7 strint_echo, Dec 11, 2017
  8. DSXDATA
    DSXDATA New Member
    Oct 20, 2015
    185
    64
    Those areas are only accessible to the users of the system. The administrators are not always users - as is our case. We have no realtime visibility of system status which can make monitoring and diagnosis harder than necessary.
  9. strint_echo
    Oct 11, 2016
    So you want detailed server activity with zero user authentication? That seems... ill-advised...
    How do you have administrators that aren't users? Genuinely curious.
  10. DSXDATA
    DSXDATA New Member
    Oct 20, 2015
    185
    64
    We are a PBX hosting provider.
  11. DSXDATA
    DSXDATA New Member
    Oct 20, 2015
    185
    64
    Its not zero authentication - its zero user accounts. Only the PBX admin portal. Yes we can create fake user accounts to get visibility, but that makes our clients uncomfortable and increases both complexity and potential for misuse. So, we'd like to be able to see a fuller range of the real-time activity directly from the PBX admin portal.
