PBX Delivers Audio - Terrible call quality
Discussion in '3CX Phone System - General' started by Tucker, May 26, 2017.
  1. Tucker
    May 26, 2017
    When I check "PBX Delivers Audio" the audio quality becomes terrible. Our routers do not support full cone (Watchguard) so this is a must for remote extensions. When it is unchecked quality is very good, when it is checked it sounds like a low bit rate tin can...
    How can I fix this?
    11,084
    325
    You are forcing the audio to route to and from the server...so, it could be putting a bit of a strain on your network and/or the server, depending on your configuration. It may be the Codecs that the sets are using, do you use G711, they tend require the least processing power. Do the logs show transcoding happening? Is this between remote extensions at the same location, or back to a set at the server location?
  3. complex1
    complex1 Active Member
    Jan 25, 2010
    814
    49
