"PBX delivers Audio" .... yes or not ??
Discussion in '3CX Phone System - General' started by itgs, Apr 22, 2009.
  1. itgs
    Nov 8, 2008
    63
    All my extensions are G729 licensed "on board" (Linksys SPA941).
    I would understand if I need to set the "PBX delivers Audio" checkbox on or off and what about the same setup in the provider section (my provider support G729 too).
    Thank you for clarification.
    Best regards
  2. amygoda
    amygoda Member
    Sep 18, 2006
    436
    If you have free version do not set it to yes
    because no g729 in free version
  3. itgs
    Nov 8, 2008
    63
    I have the licensed version (4 licenses).
    I want know if that option affect the g729 licenses consuming.
    Thank you
  4. amygoda
    amygoda Member
    Sep 18, 2006
    436
    yes it is
    so you can use it if you need
    but with out it better
  5. ciscotech2007
    Jan 27, 2009
    94
    If you paid for 3CX mini you need to communicate with 3CX directly about your licensing to confirm what you should do in this situation.
  6. itgs
    Nov 8, 2008
    63
    I thought I need to buy support to contact 3cx directly.
    How can I contact 3cx staff ?
    Thank you
  7. worksighted
    worksighted New Member
    Aug 19, 2008
    204
    PBX delivers audio simply means that the PBX must proxy audio for that extension. This setting should almost always be enabled for your voip line. For an extension you may or may not enable this, but it doesnt effect the codecs you can use. If you enable this, then the PBX will proxy all audio for that extension, even if speaking between extensions on the same network which normally, happens directly between the endpoints. But, again, if both endpoints support G729, this isnt necessary.
    In the end, you shoudlnt need to enable PBX delivers audio for the extnesions just to support G729. This should be enabled on your VoIP trunk though since the PBX must proxy all audio over the trunk.
    Best,
    Mike
  8. itgs
    Nov 8, 2008
    63
    Hi Mike, and thank you for reply.
    My 3cx is hosted on a dedicated server with public ip address. All the extensions (Linksys SPA941 - G729 licensed) are remote , behind router, and different ip address.
    I would limit best I can the 3cxn G729 license usage.
    If I set on every voip line the option "PBX Delivery Audio" and enable ONLY G711 codec (so 3cx don't use license for it), and set the option "Pbx Delivery Audio" on the extensions , could I obtain the result ?
    In other words... coul I limit the G729 license usage ONLY for the extensions ?
    Thank you and excuse me if I misunderstood your clarifications.
    English is not my mother language.... :)
