PBX Express Repo Change
Discussion in '3CX News / Tech Articles / Product Releases' started by stefan, Aug 22, 2017.
  1. StefanW
    Jun 2, 2009
    1,222
    93
  2. northfield
    Aug 20, 2013
    19
    I'm sure most people that don't do this every day are in the same boat as I am. This means nothing to me. How can I tell if I need to do this or not? I set this up myself a long time ago and have no idea if I used the express or not.
  3. agp
    agp 3CX Team
    Aug 19, 2015
    151
    22
    It's pretty simple:
    1. Did you use https://pbxexpress.3cx.com to setup your PBX? If yes then move to #2. If not then you are not affected.
    2. Did you choose to host it on your own account? If yes then move to #3. If not then you are not affected.
    3. Was your instance created before 11/08/2017? If yes then move to #4. If not then you are not affected.
    4. If you reached this step it means that you ARE affected and need to take the following action:
    Logon to your machine via SSH and run the following two commands:
    Code:
    sudo echo "deb https://downloads.3cx.com/downloads/3cxpbx/ /" | sudo tee /etc/apt/sources.list.d/3cxpbx.list
    sudo apt-get update
    That's all.
