PBX Express should set host to Time Zone chosen in setup
Discussion in 'Ideas' started by accentlogic, Jun 27, 2017.
PBX Express should set host to Time Zone chosen in setup 5 5 3votes
5/5, 3 votes
  1. accentlogic
    accentlogic New Member
    Nov 14, 2013
    190
    79
    On PBX Express setups, at least with Google Compute using the new createinstance script, we have found the PBX timezone to be incorrect, causing issues with office hour settings
    Currently, we manually SSH into the VM and update the host time zone with "dpkg-reconfigure tzdata".
    I think it would be preferable if the 3CX installer would take the PBX timezone and push it to the host.
  2. vkd
    vkd
    May 9, 2009
    We also found this same issue with the PbxExpress in combibnation with OVH.
    We also had to SSH into the VM to correct the timezone.
    So yes, i also agree that this should be selectable during the PbxExpress setup.
