PBX Express Time Zone Set
Discussion in '3CX Phone System - General' started by Eric Osborn, Jun 26, 2017.
  1. Eric Osborn
    Mar 24, 2017
    27
    It doesn't seem like time zone setting is working, where could I find the actual time of this tenant? Location is getting closed messages when they are actually open.
    Thanks,
    Eric
  2. accentlogic
    accentlogic New Member
    Nov 14, 2013
    181
    77
    We have been manually setting the timezone on the PBX host after installation.
    1. SSH into the virtual machine host
    2. "sudo -s" to become root user
    3. run "dpkg-reconfigure tzdata" and use the GUI to select the correct timezone.
    I have not checked with support yet to see if the timezone settings in 3CX should be pushed to the host, but that seems reasonable. Until that works, this should do the trick.
  3. Eric Osborn
    Mar 24, 2017
    27
    Great, thank you. It would be great if that is pushed to host as well as presenting the current time on the 3CX portal. With OVH my root password doesn't seem to be working. Is that set during the PBX express installation or is that something OVH is setting? I have a ticket open with them as well.
  4. accentlogic
    Nov 14, 2013
    181
    77
    That would be something for OVH. We are using Google Compute, which has an SSH option for existing virtual machines.
  5. Eric Osborn
    Mar 24, 2017
    27
    Okay. Thanks again!
