PBX Express VM Name and Backup Restoration - Google Compute Engine
Discussion in 'Ideas' started by techsitters, Oct 11, 2017.
  1. techsitters
    Sep 29, 2014
    For users running multiple instances of 3CX, the naming when the VM is created is very difficult to use when there are many VMs. It would be nice to be able to specify the VM name (which affects disk, network adapter, ip, and snapshots) or simply use the chosen 'Hostname' from the PBX Express as the machine name instead of the current naming.
    PBX Express also needs a way to restore a backup during machine setup. Currently, if a user deployed with PBX Express wants to upgrade their license via a backup/reinstallation, this task is more difficult using PBX Express.
