PBX not avaialable via FQDN
Discussion in '3CX Phone System - General' started by GI Germany, Dec 28, 2017.
  1. GI Germany
    Dec 28, 2017
    11
    Hey Guys,
    i had to install my 3cx completely new caused by an HDD failure. Now my 3cx is working except the availability over fqdn.
    if i want to enter the management console or set up remote extensions there is no connection.
    router setup is the same as before (was running fine)
    any suggestions?
  2. GI Germany
    Dec 28, 2017
    11
    when i type my WAN-IP:5001 is can access the management console.
  3. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    219
    Who is providing your FQDN?
    Have you specified the correct FQDN during 3CX installation (new installation / restore from backup)?
    Does your FQDN resolves properly to your public IP?
  4. GI Germany
    Dec 28, 2017
    11
    it is the 3cx FQDN.
    I did a new installation with the newest version.
    when i do a dns lookup it resolves my static ip so if i place https:// FQDN :5001 i can access my management console. but my sip clients doesnt connect.
  5. sip.bg
    Nov 7, 2016
    704
    219
    Have you run firewall checker, i.e. do have correct port forwarding / NAT in place?
    Reprovision 3CX clients and IP phones, if they don't connect.
  6. GI Germany
    Dec 28, 2017
    11
    i tried something and i am curiuos about it.
    if i type https://IP:5001 i can type in my credentials und access management console.
    if i type https://FQDN:5001 i get the same log in field but it does not accept my credentials.
    kind of wired
  7. GI Germany
    Dec 28, 2017
    11
    i did the all the NAT previously on the router. after my hdd crashed i did the whole server new. router setup did not change.
  8. sip.bg
    Nov 7, 2016
    704
    219
    No idea, try clearing your browser cache or access it from another computer.
  9. eddv123
    eddv123 Active Member
    Aug 15, 2017
    909
    138
    If they are not connecting I would try and re-provision one of these clients as a test and see if they work. Worth a check.
  10. GI Germany
    Dec 28, 2017
    11
    it is the same on different workstations. i keep try figuring it out.
    I provisioned the clients new.
  11. GI Germany
    Dec 28, 2017
    11
    if the fqdn is not working... can i set the the server IP as sip server in the Phone?
  12. sip.bg
    Nov 7, 2016
    704
    219
    If you configure manually IP phones, yes, you can.
    If phone is reprovisioned you may lose your setting.
    Check provisioning path, it may differ into new installation, if made, PBX restore from backup should use the same path
  13. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,443
    282
    Hello @GI Germany
    Did you restore a backup to setup your PBX or was it a new installation? Make sure that you have used the correct licence key that was bound to your FQDN. If you would like you can send me your FQDN and licence key in a private message and i can check whether your key is bound to the correct FQDN.
