PBX Ver 8
Discussion in 'CRM / Helpdesk / App Integration' started by Molsen6, Sep 3, 2009.
  1. Molsen6
    Mar 14, 2007
    32
    When will Vad be able to run against V8?
    /Michael
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,473
    94
    When V8 will be fully released you will have a Functional Supported Vad!
  3. zensoftware
    zensoftware New Member
    Aug 23, 2007
    225
    Hi Leonidas,
    As we are on Release Candidate stage, is the VAD fully functional?
    Do we have to wait for the actual release?
    Regards,
    Emmet.
  4. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    Hi Emmet,
    A new release of the VAD which works with 3CX V8 is coming very soon. Maybe tomorrow you have news about it...
    The VAD will continue fully functional until the end of the beta period.
    Regards,
  5. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    Will application built with he VAD afer the beta period stop working until upgrade as well? Or just the designer? And how much is the VAD going to cost?
  6. VAD_Support
    Aug 6, 2009
    690
    The disigner will continue working, but just allowing to use a limited set of components from the toolbox.
    Generated applications will continue working too.
