PBX wont enable
Discussion in '3CX Phone System - General' started by BMX, Oct 22, 2007.
  1. BMX
    BMX
    Oct 22, 2007
    My PBX wont enable and Im kinda a noob to all this so all opinions welcome :D
    Thanks..
    http://rapidshare.com/files/64244161/DRP_200710211922.zip.html[/url][/code][/list]
  2. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    According to the logs, what i saw is... Port 5060 is already in use, maybe you have a softphone installed on the same Computer you're trying to make 3CX work? you can also go to Web Admin 3CX and on general settings change Sip Port to something else you want. or you can change that other software you're using...
    Cheers
  3. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    A softphone wouldn't cause a conflict, I use one on my server for parking lines. Do you have another PBX on the same machine?
  4. BMX
    BMX
    Oct 22, 2007
    Another question
    Is it possible for somone to call me with a landline to my sip line?
  5. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    Land lines need a traditional number to call. Try http://www.sipbroker.com, they provide local access numbers in a huge amount of cities that forward to SIP.
