hi,
i use 3 api with http, to make webcall back. my webcall back redirect to specific extension, which is not registered but redirect to call queue when it's on office hours... but with v9, the 3cx is not allow to forward call when extension is not registered...
there is mean to allaow this ?
tks advance.
the log when it's webcallback
12:11:44.994 [CM503020]: Normal call termination. Reason: Not available
12:11:44.994 [CM503016]: Call(465): Attempt to reach <sip:
[email protected]:5060;nofwd=1> failed. Reason: Not Registered
12:11:44.994 [CM503017]: Call(465): Target is not registered: Ext:Ext.998
12:11:44.994 [CM503010]: Making route(s) to <sip:
and when it's not api
12:15:17.473 [CM505001]: Ext.128: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 4.0.13336.0] PBX contact: [sip:
[email protected]:5060]
12:15:17.473 [CM503002]: Call(469): Alerting sip:
[email protected]:1096;rinstance=982b2bfc9a1170fb
12:15:17.317 [CM503025]: Call(469): Calling Ext:Ext.128@[Dev:sip:
[email protected]:1096;rinstance=982b2bfc9a1170fb]
12:15:17.270 [CM503004]: Call(469): Route 1: Ext:Ext.128@[Dev:sip:
12:15:17.270 [CM503010]: Making route(s) to <sip:
12:15:17.270 [CM505001]: Ext.801: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CX Queue;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Queue Manager (q=801)] PBX contact: [sip:
12:15:17.270 [CM503001]: Call(469): Incoming call from Ext.801 to <sip:
12:15:16.848 [MS211000] C:467.1: 192.168.1.248:5306 is delivering DTMF using RTP payload (RFC2833). In-Band DTMF tone detection is disabled for this call segment.
12:15:16.567 [CM503007]: Call(468): Device joined: sip:
[email protected]:5488
12:15:16.567 [CM505001]: Ext.801: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CX Queue;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Queue Manager (q=801)] PBX contact: [sip:
12:15:16.551 [CM503002]: Call(468): Alerting sip:
12:15:16.410 [CM503025]: Call(468): Calling Ext:Ext.801@[Dev:sip:
[email protected]:5488]
12:15:16.363 [CM503004]: Call(468): Route 1: Ext:Ext.801@[Dev:sip:
12:15:16.363 [CM503010]: Making route(s) to <sip:
[email protected]>
