PBXExpress or Cloud and QoS
Discussion in '3CX Phone System - General' started by bigdessert, Apr 3, 2017.
  1. bigdessert
    Apr 3, 2017
    21
    How are you handling hosted virtual 3CX installs and QoS? To my understanding most cloud providers don't have any QoS on traffic in their network.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,444
    459
    Hello @bigdessert
    Since you have SSH access to your cloud instance you can technically implement QoS (https://www.3cx.com/blog/voip-howto/qos-linux/) but i would advise against it since you wouldn't want to interfere with whatever the provider has in place for your instance. And since your instance is dedicated for the PBX then i do not see the point of doing so.
    The place where you might want to implement QoS is at the remote location where the phones are located.
