PBXExpress roadblock
Discussion in '3CX Phone System - General' started by tsteffens, Mar 29, 2017.
  1. tsteffens
    Jul 14, 2011
    85
    I am trying to test PBXExpress and using our own AWS account. I have created the user in IAM and setup the policy permissions AmazonEC2FullAccess for the user. When I get to the step "Cloud Provider" I am getting this message when choosing the instance type and clicking next.
    Code:
    Error: The specified instance type can only be used in a VPC. A subnet ID or network interface ID is required to carry out the request.
    In order to create virtual machine, you need to grant policy 'AmazonEC2FullAccess' to the user and have available limits of running instances.
  2. johnroche
    May 11, 2017
    I am having the same issue did you ever get a resolution
  3. bigdessert
    Apr 3, 2017
    21
    Nope, got nowhere with this. Gave up.
