Solved PbxExpress server down?
Discussion in '3CX Phone System - General' started by vrn657, Jun 21, 2017.
  1. vrn657
    Jun 21, 2017
    Hello!
    I'm using PbxExpress a few weeks now. Suddenly there is not any response from the system (Android clients are not able to connect, 3cx management console returns time-out).
    Any suggestions/ ideas?
    Many thanks!
  2. agp
    agp 3CX Team
    Aug 19, 2015
    151
    22
    Hi @vrn657 ,
    If you have selected the 3CX Trial Account under Cloud Providers step when registering, then you might have missed the note at the bottom saying that the 3CX Trial Accounts are valid for 29 days.
  3. vrn657
    Jun 21, 2017
    Thanks agp!
    I missed this small detail that explains everything!
