Perform receptionist operations
Discussion in 'Ideas' started by craigreilly, Mar 24, 2018.
Perform receptionist operations 4.7 5 7votes
4.7/5, 7 votes
  1. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,569
    302
    Perform receptionist operations like set status, set reminders (wake-up call), Assign and Clear extensions (Check-in/out)
    (Available in Standard, PRO and ENT Editions)
    I want receptionist to be able to set Status (as users call in the morning and say I won't be there - so she can make the change) - but not Assign and Clear extensions, as we are not a hotel. I do not want her to accidentally delete someones voicemails.
    Please consider making each one a separate check box.
    Reminder
    Assign/Clear Extension
