Permanently Disable Auto-Answer feature
Discussion in 'Windows' started by rscl.mumbai, Feb 4, 2011.
  1. rscl.mumbai
    Jul 22, 2010
    8
    Is there anyway to permanently disable the Auto Answer function; may be in registry or at any other place.
    Thank you.
    Best regards,
    Sans
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    Hi, this is a phone related question; please let us know what phone you are using?
  3. rscl.mumbai
    Jul 22, 2010
    8
    Sorry, I missed that.
    I am using "3CXPhone 5" on Windows 7.
    http://www.3cx.com/downloads/3CXPhone5.msi
    Thank you.
