Permissions set for "editing own extension"
MSIM
Hello 3CX Forum,
I would like to know if it is possible to adjust the permissions the setting “editing own extension” of a user for allowing him to edit his BLF keys but disabling him from messing around with the telefoneprovisioning. The other settings in “editing own extension” are fine the way they are by default.
Thanks in advance,
MSIM
Hello MSIM,
Once that option is enabled the user will have access to the provisioning settings. You may submit your idea at www.3cx.com/ideas.
Get 3CX - Absolutely Free!
3CX
