Personalized fax DID - solved
Discussion in 'Ideas' started by Lance Lavery, Mar 14, 2018.
  1. Lance Lavery
    Mar 14, 2018
    11
    Hi all,
    Another thing I have noticed missing, personalized FAX DID's.
    Everything is in place but no tie in. DID's, Fax to email service, just not implemented.
    Example, the HR department fax's do not need to be seen by the operator answering the phone.
    But without personal DID fax numbers, an added expense of a real fax machine and endpoint are needed to keep personal matters personal.
    Another example- A staff member working late and needing a signed contract from a client. What are you supposed to do wait until the morning to get it or spend more money on a real fax machine and endpoint.
    Another missed opportunity to customize and fit the client better.
    Lance
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,997
    190
    i have a DID assigned to me for Faxes... what's the real issue?
  3. Lance Lavery
    Mar 14, 2018
    11
    Please explain. I see no mention in the manual or forums that covers this topic. If you are just using a did to an ATA, what a waste.
  4. craigreilly
    Feb 1, 2012
    2,997
    190
    under Inbound Rules... open a DID.
    and in the manual under Inbound Call Routing:
  5. Lance Lavery
    Mar 14, 2018
    11
    Brilliant. This needs to be more clearly outlined in the manual. And brings me closer to choosing 3CX.
    Lance
  6. craigreilly
    Feb 1, 2012
    2,997
    190
    Funnily enough I knew right off. “routing incoming calls”. Some are voice calls. Some are fax calls. Perhaps the guide could say Inbound Call/Fax Routing.
    Good luck.
    Lance Lavery likes this.
