Phone Advice
Discussion in '3CX Phone System - General' started by hashkent, Apr 26, 2011.
  1. hashkent
    Apr 24, 2011
    5
    I'd like some advice on the best phone for
    - 1-2 User Extension Lines or 1 if call waiting allows for a second call to come under the primary
    - Agent Login / Logout Queue Buttons (perhaps with indicator)
    - 1-3x Shared Parking Buttons
    - Disabling of missed call log (i.e so missed calls from queues don't show up).
    Would something like Grandstream GXP2120 work or is there something better?
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    I don't think any phone allows for Agent Login/Logout
    As for the other features the Grandstream will work, also check out the Cisco SPA504G and the Yealink models.
  3. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    Cisco SPA525G2 is a good phone aswell
  4. smb1
    smb1 New Member
    Mar 18, 2009
    104
    The SPA525G2 is a great phone and certainly has it's uses, but it is in a different price range to the other phones mentioned.
    Here in Australia it is between 1.5 and 2 times the price of a Yealink T2x series.
  5. davidbenwell
    Apr 27, 2010
    704
    ok no worries, did not see that the cost was an issue
  6. willow
    willow Member
    Mar 1, 2011
    471
    I have had really good experiences with the Grandstream line of phones. The GXp1450 is a customer favorite for its simple styple and feature set as well as price point. I don't think the 3cx will let you log in and out of individual groups via the phone buttons but you can use a dial code or the assistant to log out of all of the queues at one time. This is a feature that is really lacking at the momemt on the 3cx.
