Phone API OnCallStatusChanged not working as it used to
Discussion in '3CX Phone System - General' started by Tertius, Jul 20, 2016.
  1. Tertius
    Feb 24, 2016
    43
    Hi there,
    My OnCallStatusChanged event no longer executes it's code for incoming calls. It only fires for outgoing calls.
    Anyone experience this problem?
    Thanks in advance
    ThanhLoyal likes this.
  2. Tertius
    Feb 24, 2016
    43
    I found that the problem only happens on Windows 10 machines. The API functions as it should on Windows 7 machines. :shock:
  3. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,379
    84
    I just tested this with a simple example in Windows 10 and it works normally. What I did was this:
    [​IMG]
    If you want to try this example I have also attached the .dll of this.
    The version of Windows I ran this on successfully is this:
    [​IMG]
    It is also worth noting that I tested this on V14 SP3 Single Instance with a 4SC Pro License Key.
  4. Tertius
    Feb 24, 2016
    43
    Thanks for the response. I lost interest in troubleshooting the fault I had as I'm the only user that is not on windows 7.
    I will have a closer look at your post, test further and provide feedback.
    Thanks!
