Phone Book Pause
Discussion in '3CX Phone System - General' started by jasonhayes, Apr 15, 2013.
  1. jasonhayes
    jasonhayes New Member
    May 9, 2012
    132
    7
    Does any one know how to add a pause in the phone book. This is for when you need to call a number, then select an option. An example is like the 3CX software does it's self you call 332321 and then pick option 2 then option 3. I want to add an phone book entry that will call 332321 then pause, then dila 2, then pause, then dial 3.
    10,356
    224
    Unfortunately, the way SIP works, you generally can't insert a pause in a stored string. The exception is an analogue set that has memory built in. The reason is that the "first" part, the dialled number, is sent as a complete "packet", the portion after is sent as DTMF.
