Phone book
Discussion in 'iOS' started by TotallyVoIP, Nov 13, 2010.
  1. TotallyVoIP
    Jul 2, 2010
    77
    With the phone book driven from exchange sync'ing when I try to call someone the application just minimises?
    Is this fixed and I'm just having issues from the beta, or can anyone else confirm this who did not use the beta versions?
    thanks
  2. StefanW
    Jun 2, 2009
    1,230
    95
    my phone is attached as well to my exchange and this shiuld be fixed in the final version
  3. TotallyVoIP
    Jul 2, 2010
    77
    I'll remove and re-install and let you know if this continues or resolves.
    thanlks
  4. Sarah Hastings
    Nov 24, 2010
    15
    Also you may need to sync your phonebook with something other the exchange and see if that makes a difference.
