Phone Busy
Discussion in '3CX Phone System - General' started by wilco, Jul 7, 2008.
  1. wilco
    Nov 12, 2007
    36
    If the phone is busy can i let them wait with music and try it after 15 seconds or must i make a Digital Receptionist ?
  2. wilco
    Nov 12, 2007
    36
    but i want it then whitout that somone pick it u
    the have directly that menu?
  3. francesco
    francesco New Member
    Jun 23, 2008
    102
    you can configure a queue with only 1 agent
  4. wilco
    Nov 12, 2007
    36
    How can i do that
    is there a doc that i can use
  5. wilco
    Nov 12, 2007
    36
    Ok thanks i will try that
  6. wilco
    Nov 12, 2007
    36
    I installed the call queue
    but i have 3 sip phones if i call with 1 and 2 and i try to connect with phone 3 to 1 then i come into the Queue that is good.
    but if i hangup phone 1 or 2 then its disconnect 3 olso?
    can i change somthing to resolve my problem
  7. Anonymous
    Anonymous Guest
    Wilco,
    Are you sure you are doing a blind transfer from the phone?
    What phone are you using and what buttons are you pressing?
  8. wilco
    Nov 12, 2007
    36
    i use for phone 1 a spa921 phone 2 3CX client and on phone 3 olso the 3CX client
    phone 3 is comming into the wait tone but if i end an phone call then phone 3 get a busy tone
    but i want somting to press 1 for voicemail and press 2 to wait or somthing is that possable
    ***UPDATE****
    i use "Select a destination for this call if it reaches Maximum Queue Wait Time configured in "Other Options". "
    and select a Extension and this is working now?
    but now i can not use a option like voice mail
    if i use a Digital Receptionist
    0 repeat prompt
    1 go to voicemail
    and by timeout do to ring queue
    if i use this optiins then 1its give a " transfer failt phone is busy""
    but there is the ring queue for or not?
  9. Anonymous
    Anonymous Guest
    Wilco,
    To clarify:
    Calls come in to DR.
    0 - Repeat Prompt
    1 - Voicemail of an extension
    Fallback goes to queue.
    1 is not working. Can you tell me what you have configured 1 to be?
    Thanks,
  10. wilco
    Nov 12, 2007
    36
    no the queue is not working
    it go from menu to i will transfer you en then i hear the voice transer faild phone is busy?
  11. Anonymous
    Anonymous Guest
    I see.
    Are you sure that agents are logged in to the queue? Agents must be registered and logged in (Action > Queue > Logged in to all queues from the VOIP client).
    Thanks,
