Phone constanly re-registering
Discussion in '3CX Phone System - General' started by nitterhouse, Jun 27, 2008.
  1. nitterhouse
    Jun 24, 2008
    What would cause several phones to constantly keep re-registering about every 5 - 10 seconds? This is occuring on multiple extensions (not all) on two different servers. Here is an example of the logs:
    12:28:02.468 ExtnCfg::updateContact [CM504002]: Ext.303: a contact is unregistered. Contact(s): []
    12:28:01.750 ExtnCfg::updateContact [CM504001]: Ext.303: new contact is registered. Contact(s): [sip:303@192.168.3.182:5060/303]
    12:27:57.828 ExtnCfg::updateContact [CM504002]: Ext.303: a contact is unregistered. Contact(s): []
    12:27:56.781 ExtnCfg::updateContact [CM504001]: Ext.303: new contact is registered. Contact(s): [sip:303@192.168.3.182:5060/303]
    12:27:52.375 ExtnCfg::updateContact [CM504002]: Ext.303: a contact is unregistered. Contact(s): []
    12:27:51.718 ExtnCfg::updateContact [CM504001]: Ext.303: new contact is registered. Contact(s): [sip:303@192.168.3.182:5060/303]
    12:27:47.437 ExtnCfg::updateContact [CM504002]: Ext.303: a contact is unregistered. Contact(s): []
    12:27:46.718 ExtnCfg::updateContact [CM504001]: Ext.303: new contact is registered. Contact(s): [sip:303@192.168.3.182:5060/303]
    12:27:42.703 ExtnCfg::updateContact [CM504002]: Ext.303: a contact is unregistered. Contact(s): []
    12:27:41.703 ExtnCfg::updateContact [CM504001]: Ext.303: new contact is registered. Contact(s): [sip:303@192.168.3.182:5060/303]
    12:27:37.718 ExtnCfg::updateContact [CM504002]: Ext.303: a contact is unregistered. Contact(s): []
    12:27:36.734 ExtnCfg::updateContact [CM504001]: Ext.303: new contact is registered. Contact(s): [sip:303@192.168.3.182:5060/303]
    The phones are UTStarcom F1000G WIFI. The phones are not losing wireless communication during this period.
    Thanks.
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Set your phone's "Register Expiration" to longer time. Normally, the default value is 3600 sec.
