Phone doesn't ring
bab
Any ideas why my iPhone does not ring. I can call out but not receive. PUSH is enabled on the phone. I have a Patton FXO.
There might be six-seven reasons for this, most of them due to (mis)configuration. Usually, the first recommended person to ask for guidance is your 3CXPhoneSystem's administrator.
If the App is open on the iPhone, and you receive a call, does it ring? In other words, does it just appear to be a Push issue when the App isn't open?
Is Push working for you on any other devices, Android or Apple?
No iphone rings, even with app open.
Does this (not) happen when using both 3/4G and Wifi?Local network (Wifi), and remotely?
Do other iPhones, on the same PBX work correctly?
What does a registration attempt, from the iPhone look like in the 3CX logs?
Have you tried re-provisioning?
It's working. Don't know why really. Using UDP and not TCP, maybe why?
Getting Started - Admin
Tammy_53
Get 3CX - Absolutely Free!
3CX
