Phone Firmware Provisioning Snom
Discussion in '3CX Phone System - General' started by claxtro, Sep 7, 2011.
  1. claxtro
    Mar 12, 2011
    22
    Have a question on provisioning of firmware for the Snom phones. Provisioning of settings works great, firmware I am having some issue. I have the bin file in C:\ProgramData\3CX\Data\Http\Interface\provisioning\firmware\snom but it's looking for the snom821.xml file and I am unable to locate it. See error log below from Snom. Please advise.
    Fetching FW URL: 172.20.x.x:5000/provisioning/firmware/snom/firmware821.xml done, result 404
    --Rob
    StarTribune
  2. madigan
    Nov 10, 2010
    6
    Hi Rob,
    that's correct behaviour. It's not possible to point to the bin file directly.
    In you case you would need to create an xml file named firmware821.xml and store it in the same folder.
    The file should look like this:
    Code:
    <?xml version="1.0" encoding="utf-8"?>
    <firmware-settings>
    <firmware perm="">172.20.x.x:5000/provisioning/firmware/snom/[name of bin file]</firmware>
    </firmware-settings>
    Good luck!
    madigan
  3. claxtro
    Mar 12, 2011
    22
    Thanks Madigan.
    Yes, that did the work. What I found though is we need the http:// at the beginning in the XML file to make it work. So a phone is plugged in for the first time, downloads the settings which prompts the Snom phone to look for the updated firmware and starts updating automatically! The only thing is the time it takes for first time deployments which can be up to 10 minutes as the phone first goes through its initial bootup,then firmware upgrade. Thanks again.
    --Rob.
    <firmware perm="">http://172.20.x.x:5000/provisioning/firmware/snom/[name of bin file]</firmware>
  4. madigan
    Nov 10, 2010
    6
    Sorry, Rob. Of course http:// is required. I just accidentally removed it when pasting your IP in the example link ;)
    However, I'm glad you could sort that out..
    madigan
