Phone has been disconnected - error: 503
Discussion in 'Windows' started by Nathanielyb, Oct 16, 2012.
  1. Nathanielyb
    Oct 16, 2012
    I have configure my firewall and norton...I have tried different stun servers ...I have done everything and I cannot get this to work. Please help.
    Translation file OK
    Attempting to connect commercial.onestreamnetworks.com
    Phone got as local port 56073
    Jabra connected
    RTP engine OK
    SIP engine OK
    Sound mic device OK []
    Sound ring device OK []
    Sound speaker device OK []
    Sending STUN request
    Not connected: Server unreachable
    Phone is no longer connected
    Phone connection failed, PBX not responding
  2. mixig
    mixig Active Member
    Dec 13, 2011
    524
    12
    just shoot from the hip:
    does your phone has default gateway? Can you see traffic from your phone is it passing through your firewall rule?
  3. joshhough
    Feb 22, 2011
    72
    is this being used as a remote extension? If yes try through the Proxy server - it makes things a lot easier!
  4. leejor
    10,868
    304
    If this is, in fact, being used as a 3CX extension, with the PBX being located at commercial.onestreamnetworks.com , then be sure that the Domain Name is datafilled in the PBX or it will reject any incoming calls using it.
    The 3CX PBX logs should confirm this, if this is the cause of the failures.
    Since you are not able to reach a STUN server there may be other issues as well. Have you tried using from any other locations? Are you trying from behind a Proxy Server at an office?
  5. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    try extensions--->other--->and assure disallow outside of use on LAN. also as joshhough said using SIP Proxy server does eliviate alot of problems when using remote extension also hardward VPN is always best route from my experience.
