PHONE IS NOT MAKING OUTBOUND OR INBOUND CALLS!!
Discussion in '3CX Phone System - General' started by apal1990, Jul 3, 2008.
  1. apal1990
    Jul 3, 2008
    hey everyone, i am farily new to VOIP it self, but i have set up both the gateway which is a linksys 3102 and the 2 ip phones which are Aastra 33i's. Now when i try to place a call the call fails every single time. the same with recieveing calls, i call my work number and all of the original phones ring but not my ip phones.
    I have upadate the firware
    i have version 6.0 of 3cx
    the aastra 33i are connected and registered, but say idle in quotes the same with my linksys. the light is green but the phone line is not active at all.
    this is what the server status emits when i try to place the call:
    09:18:55.468 Call::Terminate [CM503008]: Call(60): Call is terminated
    09:18:55.421 Call::RouteFailed [CM503015]: Call(60): Attempt to reach "98323382326"[sip:98323382326@10.10.10.210:5060] failed. Reason: Not Found
    09:18:55.421 CallLeg::eek:nFailure [CM503003]: Call(60): Call to sip:8323382326@10.10.10.211:5060 has failed; Cause: 404 Not Found; from IP:10.10.10.211:5060
    09:18:55.359 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(60): Calling: PSTNline:8323382326@(Ln.10000@Line 1)@[Dev:sip:10000@10.10.10.211:5060]
    09:18:55.359 CallCtrl::eek:nSelectRouteReq [CM503010]: Making route(s) to "98323382326"[sip:98323382326@10.10.10.210:5060]
    09:18:55.343 Extension::printEndpointInfo [CM505001]: Ext.100: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Aastra 33i/2.1.0.2145] Transport: [sip:10.10.10.210:5060]
    09:18:55.312 CallCtrl::eek:nIncomingCall [CM503001]: Call(60): Incoming call from Ext.100 to "98323382326"[sip:98323382326@10.10.10.210:5060
    any help would be greatly appreciated.
    can someone please help me make sense of this!!???
    much love,
    andy p
  2. SIPfun
    Jun 23, 2008
    56
    Do you have an outgoing connection to the outside world? (VOIP/PSTN)?
    Do you have a rule setup to handle your outgoing calls?
  3. Henk
    Henk Member
    Nov 13, 2007
    250
    make sure your route is configured, with that I mean:
    Your Aastra appears to have some issues
    Does not seem to be able what to do eg not registered, are all your lines nice and "green" ?
  4. Anonymous
    Anonymous Guest
    The technical support requesting here goes beyond that we can provide in the free peer-peer forums and would require finite trouble-shooting of your specific installation which we would normally do via our Support Portal at http://support.3cx.com .
    We suggest that for a little amount of money we could give you this full support or provide you with feasible alternative solutions.
    This can start from a Small Business Edition with 8 simultaneous calls and Support Contract going at Eur 375 + Eur 125 per year. We also recommend version upgrade insurance at Eur 99 per year. We can also propose larger licenses as you desire and you can eventually perform Edition Upgrades as your needs grow.
    If you have any further queries about this or how to proceed, please contact sales@3cx.com .
    Thanks,
