Phone keeps ringing with phantom calls
Discussion in '3CX Phone System - General' started by joshuao3, Apr 9, 2018.
  1. joshuao3
    Jan 11, 2013
    20
    Ever since the update to v15, some of the phones in the office ring every few minutes for no reason whatsoever. It's driving us crazy!!!!!! It looks like it's our own extension calling. Any help or insight would be appreciated.
  2. voiptoys
    voiptoys Member
    Feb 13, 2013
    314
    63
    My guess is that you are using Grandstream phones. If so, be sure to upgrade to the latest supported firmware.
    craigreilly likes this.
  3. joshuao3
    Jan 11, 2013
    20
    Yes, I am. Only the upgraded phones are having the problem. I'm also having a problem (that just started) where the phone system says I'm out of licenses when I try to make calls. We only have 5 lines, and our license is for 8 calls, and I'm getting the error when there's nobody on the phone. There used to be a way to look at the ongoing calls in realtime, but I can't seem to find that in the new web interface. Is there a place to see the current calls?
  4. joshuao3
    Jan 11, 2013
    20
    Basically, the system is full of hobgoblins since upgrading to v15. It's very very disruptive to my office.
  5. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,794
    132
    1) After upgrading the phones - factory reset? That is part of the GS process on 15.5 SP4.
    2) Active calls - Dashboard-> Number of calls in use. Click on it.
    voiptoys likes this.
  6. voiptoys
    voiptoys Member
    Feb 13, 2013
    314
    63
    Hey craigreilly, you solved a mystery for me! Thanks!
  7. craigreilly
    Feb 1, 2012
    2,794
    132
    No way I did that Matt... :eek:
